Software Update NA6005
Gestart door robstuart, december 01, 2015, 22:58:28
robstuart
Vandaag kwam automatische een software update binnen voor de NA6005 streamer.
Heb nog geen tijd gehad om te achterhalen wat de wijzigingen zouden kunnen zijn.
Rob
Marantz PM8005, NA6005, UD7007, Thorens 115 MKII, Ortofon 2M Blue, X3-MCP, VMS-30MKII, KEF IQ90, AppleTV3, JKE luidsprekerkabel en interlinks
Idem hier, update staat ook (nog) niet op de website van Marantz  :?
rexp
"Better performance and stability" werd er beloofd op het display van de NA. Ik ben benieuwd.
robstuart
Gevonden, de laatste firmware updates verhelpen de volgende problemen.
Last updated:- 30/11/2015
firmware version:- System 16.90
MODEL: NA6005/ N1B and N1SG   (MZ15-008)
1) When the customer does Pause playback in Music app after playing music from Music App of iPhone by AirPlay, the product doesn't become a standby even if the time set by the Auto Standby feature passes. The symptoms is the product doesn't change to the standby mainly because the Auto Standby feature doesn't operate correctly.
2) After the customer starts Spotify App by Marantz HiFi Remote App and plays music, the product doesn't play Internet Radio mainly because the product cannot be connected with Internet Radio even if the customer switch the input source to Internet Radio by Remote App. The symptoms is the product doesn't play Internet Radio even if the customer selects Internet Radio.
3) When the customer connects Apple Airport Express and Apple TV to the set with the Optical input, the noise might be heard from the Headphone and Audio output terminal. The symptoms is the noise might be h  eard from the Headphone and Audio output terminal.
4) Change of specification: When the customer is playing Internet Radio, the product changed the specifications not to display a play counter (elapsed time) in the FL display.
5) When the customer connects the iPod/USB or Media Server to the product and music is played, the product did an unnecessary access to server of the Last.fm. Therefore, when the Last.fm server, failed, playback of music from the iPod/USB and Media Server stopped. The symptom is the product accessed to server of the Last.fm while playing music on the iPod/USB or Media Server.
firmware version:- System 16.8D
MODEL: NA6005/ N1B and N1SG   (MZ14-112)
1) When the customer connects Apple Airport Express and Apple TV to the set with the Optical input, the noise might be heard.
2) Unit locks up in the operation from a remote app, customer switched to internet radio after connect Spotify.
3) The specific DFF files could not be played (The DFF file where Meta data of ID3 is included).
4) Miss translation in Dutch ("Zoeken naar draadloss netwerk").
5) The product will lock up in several hours when iPod is playing continuously (3-4 hours).
6) Wi-Fi might not be able to be connected with specific routers.
rexp
#4
Citeer5) When the customer connects the iPod/USB or Media Server to the product and music is played, the product did an unnecessary access to server of the Last.fm. Therefore, when the Last.fm server, failed, playback of music from the iPod/USB and Media Server stopped. The symptom is the product accessed to server of the Last.fm while playing music on the iPod/USB or Media Server.
en
Citeer5) The product will lock up in several hours when iPod is playing continuously (3-4 hours).
Hier heb ik dagelijks last van. Ik hoop dat de update deze problemen oplost, want ik heb al een paar keer op het punt gestaan dat ding het raam uit te gooien.
Citaat van: rexp op december 03, 2015, 13:33:51
en
Wacht daar even mee tot ik beneden sta  :wink:
robstuart
en
....en?
Werkt het nu beter?
rexp
Ja. De update lijkt twee van mijn grootste NA frustraties te hebben weggenomen: onverwachte vastlopers heb ik niet meer gehad, en de speler reageert eindelijk normaal op commando's die je via het frontpaneel geeft.
Bediening via de app is een groter drama geworden, want helemaal niet meer mogelijk. De app vindt de speler nog wel, maar doet daarna niets meer (zie enkel de app equivalent van het zandlopertje).
minguel
Citaat van: rexp op december 12, 2015, 11:09:19
Welke app gebruik? Die van Marantz is inderdaad een drama. Kijk bv ook naar plexiglas of bubble upn. Ik gebruik die laatste al een jaar en die werkt voor mij top.
Set 1 (woonkamer):
Marantz PM11 S2 - NA8005 - Dynaudio FOCUS 220 - REL S3
Set 2 (zolder):
SR8002 - NA6005 - JBL750
rexp
Die bubble app is er alleen voor Android, toch? Ik heb een tijdje de Technics app gebruikt, die deed het redelijk goed. De enige functionaliteit die ik echt belangrijk vind is on the fly playlists maken, dus tips zijn altijd welkom.
robstuart
Ik gebruik de Apple Remote app. Werkt snel en perfect vanaf iPhone en iPad.
Alle streaming commando's naar iTunes op de iMac gaan perfect.
Hier geen problemen na update, Marantz app doet het prima en heb het gevoel dat het laden vanaf usb nu sneller gaat.
